1 - 14 of 14 Posts
Anyone that can tell me why even with starter fluid it will only turn over and over and not start would be helpful, i replaced the coil already but with fire i dont want to spend the 250 bucks for the computer. Any suggestion?
CJ
Do you have a spark? And welcome to the board!
Hi and thanks, yes i have a spark and it only turns over, starter fluid didnt help.
Have you adjusted the freeplay in the throttle(ETC)Electronic Throttle Control?It may not be opening.That will cause that problem.This is something to try before you spend $250 bucks.
Hey thanks, Im not sure how to adjust it or where is is, i can look it up, thanks again for the tip
It is inside the box where the thumb throttle is.
even if i put starter fluid directly in carb i would need to adjust it? Ive got spark but not even trying to start, just turns over and over hooked directly to my car battery.
Discussion Starter #8
Im not mechanic but i don't really want to get ripped at the dealer to have it be something i missed but i know now its not the computer since ive got spark. anymore help appreciated before i give up and start saving for a dealer repair.
"If" the ETC adjustment is the problem,yes you would have to adjust it.Do you have any freeplay in the thumb throttle at all?
No fire
Got the same prob with my 99 500 sportsman,had no spark coil tested bad, replaced coil, now have spark but no fire.goig to check ETC today. Hope we can both get this fixed and back on the trails. will be wathcing this post for any more hints.
Like said, start with the ETC switch, there should be a very small gap in the contacts. I have seen 500 motors in the past that with the spark plug out had good spark, but under compression it just wouldn't hold up. I'd try throwing a new plug in it. Have you tested compression? Leakdown? Have you had the carb apart to verify there isn't something blocking a passage? I know it's easy to do, but starter fluid isn't always a good fix. let me know what you find, i'll do some more looking into it.
dont know if you fixed your problem yet or not, but if your interested in used parts im parting out an 03 ,chucked a piston and needed to much to bother rebuilding
1 - 14 of 14 Posts
