I have a 2003 Scrambler 500 and when I start and run the ATV it sounds like the starter is staying engaged. This is in Drive, Reverse or Neutral.
Any suggestions?
Can't be or it would have been destroyed by now, unless you're shutting it off almost immediately and not revving above idle.
Sent from my SM-G930R4 using Tapatalk
Sounds like you need a new Bendix or you might get away with cleaning the old one. They will run a little after initial startup and that's fairly common but if it continues to stay engaged it will work on the starter pretty quick.
If the starter is continuing to run, it will be running when you shut the key off or it will start cranking as soon as you turn the key on.
Snowed here in Central IL this morning - 50 car pile up in Chicago (during state wide lock down) :rolleyes: - supposed to snow here again on Fri with a high of 45*, but on Sun it's supposed to be in the 60's - it's called climate change and it changes every day :unsure:
