has anyone had their starter repaired, then when it gets cold i tried to start the bike, it constantly tries to start but never does, i had to unhook the battery cable, to get it from trying, that was after turning it off, and taking the key out.
do I need a new starter??
If you are saying that the starter keeps on trying to start the quad even if you are not pushing the button or turning the key then you have an issue with the solenoid or the switch that gives it power. Solenoids are not expensive and available at any parts store. Swap it first and if still does it, then move as to why it is powering up the solenoid when you are not pushing the start button.
sounds like the contacts in the starter solenoid welded close...or a problem in the ignition switch..
