First off, new to the board. I did some searching and am still lost. I rolled my wheeler a few months ago and parked it for a while. When it rolled I was able to start it back up and drive it back to my trailer and bring it home. fast forward two months.. Installed new wheels and tires, charged battery and tried starting. it cranked awhile and then started to spit and sputter, gave it some throttle to keep it going and then lost it. After that it will just crank. I pushed it into the garage and started to do some diagnosis. Found no spark. I did the upgrade for the stator and ignition system last fall. Problem I am having is finding any info on test points for the newer CDI box and Stator. I am thinking the charger might have fired the CDI box, but the wiring does not match the stuff listed in the manual I have (official Polaris) any help?
anyone? i'd hate to go off aqain just buy new part to try to solve this. would love to find out the root cause
Could be that the gas went bad and maybe a gas line is clogged or carb is dirty. But try this, put some fresh gas and if you go to your airbox you will see a tube that is connected to the side of airbox thats the crankcase breather put your finger so that the hole where it comes out of is blocked and try starting it.worth a try!
