I have a 2003 Polaris sportsman 600 and when I put it in neutral and press the yellow back up button and turn on the key and toggle through the display I come to 4x4 and ranch icon and it says off I have pressed the button and held it down for 5 min and it will not change to on I have been having problem with the four wheel drive found that the front differential coil was bad when 12 volts was applied. I also found that when I checked the voltage with the coil unhooked noticed that the voltage was going from 2volts up to 12 traced down wiring and found that I was losing ground at the speedometer on the brown wire was not sure if speedometer is bad or I am not doing something right when I go through the menu as far as turning the icon above on
