Front of mine broken and the fender is flopping around and rubbing the coolant tank. Anyone know of a good source for used parts?
Check Ebay. Do a search for your machine then narrow it down. Powersports Nation is a seller I have dealt with in the past. There are a couple others too that I have gotten stuff from. Most are basically salvage yards for off road stuff.
Chances are that someone will have what you need!
Anyone know what years are compatible with a 2003. Manufacturers often make subtle differences in parts so you have to "upgrade". Will an 07 fit a 2003?
Here is a list of what fits from the Polaris cross reference. Doesn't show the '07 Sportsman.
I think they made a body style change in 2005 for the full size sportsman models. The 6x6 doesn't change as often. Current body on the 6x6 has been the same since 2008 I think. Some of the others will be easy to find though. The trail boss and Magnums were plentiful.
SERIES 10 PPS PTV 6X6 REAR CAB and SEAT - C10CL50AA (4978707870A04)
2009 ATV TRAIL BOSS 330 BODY, REAR CAB and FOOTWELLS - A09CA32AA (49ATVCABRR08BOSS)
2008 ATV TRAIL BOSS 330 BODY, REAR CAB and FOOTWELLS - A08CA32AA (49ATVCABRR08BOSS)
2008 ATV SPORTSMAN 6X6 BODY, REAR CAB and SEAT - A08CL50AA (49ATVCABRR086X6)
2007 ATV TRAIL BOSS 330 CAB, REAR and SEAT - A07CA32AA (49ATVCABRRBOSS)
2007 ATV SPORTSMAN 6X6 CAB, REAR and SEAT - A07CL50AA (49ATVCABRR6X6)
2007 MIL SPORTSMAN 6X6 MV CAB, REAR and SEAT - A07CL50MA (49ATVCABRR6X6)
2006 ATV MAGNUM 330 4X4 CAB, REAR - A06CD32AA/AB/AC (4999201699920169A03)
2006 ATV TRAIL BOSS 330 CAB, REAR and SEAT - A06CA32AA/AB (4999202939920293A04)
2006 ATV SPORTSMAN 6X6 CAB, REAR and SEAT - A06CL50AA (4999201649920164A04)
2005 ATV TRAIL BOSS 330 QUADRICYCLE CAB, REAR and SEAT - A05CA32EA (4999200489920048A04)
2005 ATV SPORTSMAN 6X6 CAB, REAR and SEAT - A05CL50AA (4999201649920164A04)
2005 ATV TRAIL BOSS 330 REAR CAB and SEAT - A05CA32AA/AB/AC/FA (4994839483A04)
2005 ATV MAGNUM 330 2X4 REAR CAB and SEAT - A05CB32AA (4994889488A03)
2005 ATV MAGNUM 330 4X4 REAR CAB and SEAT - A05CD32AA/AB/AC (4994909490A03)
2005 MIL SPORTSMAN 6X6 MV CAB, REAR and SEAT - A05CL50MA (4995019501A04)
2004 ATV A04CA32AA TRAIL BOSS 330 REAR CAB and SEAT - A04CA32AA/AB/FA (4994839483A04)
2004 ATV MAGNUM 330 2X4 REAR CAB and SEAT - A04CB32AA/FC (4986188618A03)
2004 ATV MAGNUM 330 4X4 REAR CAB and SEAT - A04CD32AA/AB/AC/FB (4986268626A03)
2004 ATV A04CH42AA SPORTSMAN 400 REAR CAB AND SEAT - A04CH42AA/AE/AG (4986068606A03)
2004 ATV A04CH42AQ SPORTSMAN 400 REAR CAB AND SEAT - A04CH42AQ/AR/AS/AT/AV (4987258725A03)
2004 ATV A04CH50AA SPORTSMAN 500 REAR CAB AND SEAT - A04CH50AA/AC/AE/AG (4986088608A03)
2004 ATV A04CH50AQ SPORTSMAN 500 REAR CAB AND SEAT - A04CH50AO/AQ/AR/AS/AT/AV/AW/AX (4987288728A03)
2004 ATV SPORTSMAN 6X6 REAR CAB and SEAT - A04CL50AA (4986288628A04)
2004 ATV A04CH59AF SPORTSMAN 600 REAR CAB, SEAT AND MAIN FRAME - A04CH59AF/AH/AJ/AT/AV (4986108610A03)
2004 ATV A04CH59AK SPORTSMAN 600 REAR CAB, SEAT and MAIN FRAME - A04CH59AK/AL/AN/AQ/AW (4987318731A03)
2004 ATV A04CH68AU/CU SPORTSMAN 700 REAR CAB, SEAT and MAIN FRAME - A04CH68AP/AQ/AU/CU (4987468746A03)
2004 ATV A04CH68AC SPORTSMAN 700 REAR CAB/SEAT/MAIN FRAME - A04CH68AC/AF/AH/AJ/AT/AV (4986128612A03)
2004 ATV A04CH68AK SPORTSMAN 700 REAR CAB/SEAT/MAIN FRAME - A04CH68AK/AL/AN/AO (4987438743A03)
2003 ATV MAGNUM 330 2X4 REAR CAB and SEAT - A03CB32AA/FC (4975157515A03)
2003 ATV MAGNUM 330 4X4 REAR CAB and SEAT - A03CD32AA/AB/AC/FB (4975217521A03)
2003 ATV SPORTSMAN 400 REAR CAB AND SEAT - A03CH42AA/AB/AC (4975377537A03)
2003 ATV SPORTSMAN 500 HO REAR CAB AND SEAT - A03CH50AA/AB/AC/AD/AE/AH/AJ (4975417541A03)
2003 ATV SPORTSMAN 6X6 REAR CAB and SEAT - A03CL50AA (4975687568A04)
2003 ATV SPORTSMAN 600 REAR CAB, SEAT AND MAIN FRAME - A03CH59AA/AF/AG (4977187718A03)
2003 ATV SPORTSMAN 700 REAR CAB/SEAT/MAIN FRAME - A03CH68AA/AC/AF/AH/AL (4975557555A03)
2002 ATV 325 MAGNUM 2X4 HDS REAR CAB AND SEAT - A02CB32AA/AB/FC (4970107010A03)
2002 ATV MAGNUM 325 2X4 REAR CAB AND SEAT - A02CB32AA/AB/FC (4970107010A03)
2002 ATV 325 MAGNUM 4X4 HDS REAR CAB and SEAT - A02CD32AA/AB/AC/FB (4970147014A03)
2002 ATV MAGNUM 325 4X4 REAR CAB and SEAT - A02CD32AA/AB/AC/FB (4970147014A03)
2002 ATV MAGNUM 325 4X4 FREEDOM REAR CAB and SEAT - A02CD32AA/AB/AC/FB (4970147014A03)
2002 ATV SPORTSMAN 400 REAR CAB AND SEAT - A02CH42AA (4968536853A03)
2002 ATV SPORTSMAN 500 ALL OPTIONS REAR CAB AND SEAT - A02CH50 ALL OPTIONS (4967436743A03)
2002 ATV INT'L BIG BOSS 6X6 REAR CAB and SEAT - A02CL50AA/DA (4967986798A04)
2002 ATV SPORTSMAN 6X6 REAR CAB and SEAT - A02CL50AA/DA (4967986798A04)
2002 ATV SPORTSMAN 700 REAR CAB/SEAT/MAIN FRAME - A02CH68AA/AB/AC/CA/CB (4966346634A03)
Powersportsnation.com posts stuff on ebay. You might get a better price. I bought a RZR roll cage for $300 shipped. They wanted $550 for it on their website.
Yeah, everything I have gotten from them has been through an ebay listing. Never looked for stuff on the website.
