can someone help me . I have a 2003 400 sportsman with only 200kms on the machine.I use this for plowing my driveway' as soon as the engine gets warm the bike stalls. it will start again only if i pull the choke but it wont stay running as soon as the engine cools it will start again and run again till it gets warm.also my 4x4 wont engage. I am told its because my speed odometer doesnt work. the bike only had 167 kms on it when i bought it from a friend 6 months ago and the speedodmeter failed the new ones are pricey
may be the carburetor needs cleaning, also check the fuel pump.
With the 4 whl.drive. check to see if you're getting any juice to the switch. all wheel drive light working?? check bulb also ,check circuit breakers.
is it just the speedometer-odometer not working or the whole speedo.pod??
speed pod
its the whole pod that doesnt work. and never has since i had the bike. my 4x4 dont work either because of my pod. and its over 300 for another one where i am from and i cant find a used one
its the pod no lights at all . also my 4x4 light dont come on so they tell me thats why my 4x4 dont work either
