Hi, I have a 2004 330 Magnum 4x4 and noticed a while back that the front wheels were not locked in while going down a steep hill and the back tires were starting to slide. This has happened multiple times since, but the front is engaged like normal whenever i am on flat ground or going uphill. Is this the way Polaris designs their four-wheelers or is something worn out?
That's normal. Many of the newer machines have ADC (Active Descent Control) that provides down hill 4x4. The old machines don't have that feature.
Ok thanks for the reply. I have gotten used to the Honda's where you are in 4x4 all the time. I didn't think it would be any different.
It's a lot different and takes getting used to - like when in AWD and going around a corner of a certain radius under certain conditions and only one front wheel will be pulling
