Hi,
I’ve been chasing this issue for past few weeks and can’t figure it out. I’ve got a bog when I give it quick throttle 1/4 or half way.. miss for a second or 2. Rebuilt carb, tried moving c-clip up or down a position, tried 1 1/2 to 3 1/2 turns on the mixture screw half turns at a time.
the only thing I haven’t set yet is the float level. Can this cause this bog issue? Anyone know how to check the level?
Also what is the default settings on this carb?
Thanks for an help.
Discussion Starter #2
Forgot to mention, it starts right up, idles at 1200. Works really well at wide open throttle once it gets pass the bog
Yeah - the fuel screw setting has no effect above 1/8 throttle
140698
140699
140700
