2004 magnum 330 service manual
49K views 274 replies 99 participants last post by  FPD218
Looking for a service manual for my 4 wheeler. Took it in because the 4 wheel unit wasn't engaging. payed a professional to diagnose and was told the unit was getting 12 volts and the differential was bad , couldn't rebuild and wanted 1400 dollars to replace. Bought a used unit for 400 and started to work on and found out its not getting any juice to the unit. kinda upset!!! my friend whos a mechanic said with a wiring diagram we could trouble shoot if its the switch or a fuse broken wire ect. Any help or ideas would be greatly appreciated. Thank you
#134 ·
Could someone email me a service manual for a 2004 polaris magnum 330 4x4 and help one Icelander in need
thanks
I'm sending the manual - I would normally ask you to edit your post and remove your email address unless you like SPAM, but I see your user name is spam me.
#135 ·
155285
you do not know what you have helped me a lot. So I'm trying to fix my Polaris Magnum four wheel when I ride it and give it some gas. The wrench signal starts flashing and then StAtr arrives which I do not know what it means and is trying to fix it. Thank you very much for all the help. (PS
if anyone knows what is going on I accept all the advice and help I can get
#143 ·
to the forum
#165 ·
I've been looking for the service manual for my 03 Polaris Magnum 4X4 to help troubleshoot an electrical issue and found this thread.
Is it possible to share the manual with me?
Thanks.
dnd4spd at y@h00 dot c0m.
to the forum
