I have a 2004 Polaris Magnum 330 that has a new carb, but when the engine is running gas flows out of the over flow tube. I have checked the float level according to the manual, but gas still flows while running.
Any suggestions?
I did a pressure test on the float needle, and there are no leaks. Being a new carb, would you still replace the o-ring?
