I recently changed the battery on my Predator, everything worked fine that day, then when I went to start it the following day the ignition isn't drawing any power from the battery. Battery still has power but the lights don't work, the starter doesn't work, I can't even compression start it. I think it could be a blown fuse but is there any other possibilities that may be affecting it??
Welcome to the board!
You didnt hook the battery up bass ackwards did you?
Walmart did that to my Mazda once, blew the main fuse and burnt up my radio. The next time I went in for a oil change, they broke out the drivers window. I don't go there any more!
I dont blame you :lol: It sounds like if they worked on it too much,it would be ready for the crusher.Maybe they were feeling the after effects from the night before:joint::trink4: Thats messed up.I hope they fixed it without any kind of BS
