Fan should be automatic so if there's a switch, the PO must have modded it. Some folk like to do that so the fan doesn't run while in deep water or mud.
Are you getting Check Engine on display? If so have you checked for EFI codes?... it might be the T-BAP sensor connector. If that has never been fixed on that 700 it will go bad at some point.
