Hey All,
Just changed out all 4 calipers, both master cylinders, and all new pads. Using a vacuum bleeder, I bled everything in the correct order and I have a nice firm pedal for the rear, but I can't get any pressure in the front. I did bench bleed both MC's, and retested with the finger method for the front. Over 3 quarts of fluid through the front brakes and they are still sloppy unless I press on the rears a little bit, then they firm right up.
Anything I should look for? I am at a loss. Should be an easy job.
Thanks!
Thanks!
