I have a 2004 Sportsman 400 that acts like it's possessed. I bought it new from a dealer. It has 800 miles on it, sat for two years with gas treatment in it. I took it out this year and have had stalling, missing, power loss, etc. So I did the following
removed tank, blew out screen with air
new fuel filter
new gas lines, removed and blew out all others.
new fuel pump
new air filter
new air lines to air box
new air box gasket
rebuilt the carb. using a hanes manual
new spark plug wire and spark plug
adjusted valves
I brought it to a Polaris dealer, and a former Polaris dealer and the missing, stalling, power loss continues. Does anybody have an idea what else could be wrong like electronic issues?
new fuel filter
new fuel pump
new air filter
new air box gasket
adjusted valves
The ETC could be out of adjustment in the thumb throttle housing.
Ty for responding dwhst9. I have adjusted the ETC with no success. Could it be the carb diaphragm? It seems to work fine when the carb is off the machine and I move it manually. This problem is elusive to say the least.
I have solved the problem by adjusting a combination of ecm and
air to fuel mixture screw. I found that you have to be patient
When adjusting the air to fuel. Make sure the motor is at a running
Tempurature and run it after any adjustment to make sure the motor catches up
To the Adjustment.
