i have an 04 Sportsman 700 (carb model) that will idle all day long but when given throttle it will only go to 1200rpm (if I'm lucky) and takes a while to get there. hold it wide open and it will slowly work its way to 1200. The air fuel screw is set to 2.5 turns out, needle is on the 3rd clip, everything's clean (brand new carb). now the slide doesn't appear to be moving at all, i took it apart and cleaned it and lifted it by hand it feels smooth but it wont move when I use the throttle. also, after about 5 minutes of running (I do have a fan blowing onto the radiator for cooling) the header pipe is glowing red (the Y pipe at the head of the engine). If I hold the throttle wide open and lift the slide by hand, it shoots a flame and dies. all the electronics check out, all fuses check out, the exhaust is clear. I don't know what to chase down or do next, I've exhausted all the options that I know to do. Any help or guidance is appreciated
