The final drive chain inside my 700 tranny is now sticking thru the bottom of the case. I have not diassembled it yet, but I can see it sticking thru a hole it punched in the case on it's way to death.
This would be the chain between the front and rear driveshaft outputs.
I looked at some options, a new tranny $800-$1400 depending which dealer you go to. I located a good used 04 sportsman 600 tranny. I only need the main housing (cheapest is $365 by the way). They are the same so I am swapping the 700 guts into the 600 case and will sell off the good parts of the 700 case to recoup some of my money....
Has this happened to anyone else? I've never disassembled the sportsman before. I have an 05 700 as well and I do all the main (fluid changes on diffs, tranny, engine, coolant, grease zerks) and find them very serviceable.
Day one, disassembly: (approx 1.5 hours)
bitch seat
seat
rack
rear cab
both footwells (left attached to rear cab)
clutch cover
secondary clutch
belt
battery cable
battery box
air box
tranny bolts
rear driveshaft
Observations: Came apart pretty easily, except for the roll pin. I farted around with a punch and a hammer, but got no where. A kiss with my air chisel and it was out in one second. Sec. clutch came off super easy, was a surprize. leaving the footwells attached to the rear cab made that a little faster. Also noticed that my frame is cracked, so I will weld on a small patch and paint it. Better than new
Day 2: (planned)
remove tranny without removing primary clutch? Is this possible? I hope so because I don't have the special tool required to jack it off the crank..... (edit: just found a thread suggesting using a 3/4 fine pitch thread (on a trailer ball, which I have) and a socket to jack it off the crankshaft, I'll let you know how this works!) I'd rather leave it on if I can of course!
once it's out I'll post some pics of the grenaded case and internals when I get there.
bitch seat
seat
rack
rear cab
clutch cover
secondary clutch
belt
battery cable
battery box
air box
tranny bolts
rear driveshaft
Day 2: (planned)
