1 - 8 of 8 Posts
400, 500, 600 or 700 - I'll rule out the Sportsman 90
to the forum
Early or late production?
151381
151382
Need the VIN or model number as the fans are controlled differently between models
Discussion Starter · #7 ·
OK - you have model A05MH50AG (early production) - the fan is controlled by the thermo switch in the radiator - unplug the switch, if the fan stops running, with the switch unplugged, replace the switch - if it continues to run with the switch unplugged, find the short between the two fan switch wires
151390
red/blk is hot - brn is ground
1 - 8 of 8 Posts
