my 700 efi starts fine idles fine for a few seconds and then dies.. It will restart fine. Some times when it idles it will backfire or miss out the throttle body a few times then die.. The deadman switch is fine and no air leaks around the tb. The plugs and airfilter are new. The machine will run out fine and strong no stalling after 1200 rpms just at idle. wiggled and removed all the harness plugs no corrosion and there are no codes in the computer.. any help would be nice....
bad gas? try running a bottle of fuel injector cleaner in the tank, makke sure your throttle cable is adjusted, also check your tps sensor, loosen it while it's idleing and move it till hopefully it straitans out
The gas is new ran a few tanks threw with this condition.. The cable is adj. i even took all the slack out to see if that would do it but did not help just made it rev in the turns.. I will try the tps trick tomorow thanks
