I am haveing trouble with my sportsman going into fourwheel drive in reverse only. When i hold the overide button in the fourwheel drive indicator light comes on in the gauge cluster but the front wheels dont engage.
Check the roll cage in the front differential.A round plastic like deal with rollers in it,something like bearings.If that cracks or breaks then you lose 4wd.Let us know if you find the problem.
Thank you slider but i have fourwheel drive in high range and low range just not in reverse.
A bad roll cage prevents it from going in to 4wd in reverse not forward.You can still have 4wd in forward with a bad cage.
