1 - 1 of 1 Posts
2005 Polaris Ranger
when turning the key on and brake pedal depressed, you normally hear the fuel pump energize for a couple of seconds. The problem I'm having is the fuel pump is not getting 12 volts.I have run a wire from battery to get 12 volts to fuel pump and pump works and got cart running , just to verify problem. Trying to get a wiring diagram. Question to anyone is does the 12 volts come straight from control module, or does it go thru a solenoid or relay before fuel pump?
1 - 1 of 1 Posts
