I'm low on coolant according to the reservoir, it's at minimum. What coolant do I use? How to I fill that up? Do fill in the reservoir ? I am a first time atv owner, thanks
Ronnieburgundy, what do you mean aluminum? How do I know if my is aluminum? And the reservoir is small tight location, how do you even pour it in? Sorry I'm new to atv and thanks
Discussion Starter · #4 ·
Hello!
The Polaris manual says to use their 60/40 brand, OR, you can use any GOOD 50/50 that is good for aluminum engines. And yes, if the reservoir just says you're a little low, add directly to it.
Have fun!
If you get a good 50/50 mix, you should be fine. I would recommend googling the polaris brand and just getting that, though. No worries that way.
As far as the reservoir, Autozone / Advanced Auto Parts / Walmart, any of them should have a funnel with a tube on the end. Take the red cap off, then the green insert, stick the tube in, fill to desire, put back in reverse order.
Discussion Starter · #6 ·
Hello!
Have fun!
Okay i will try that thanks
