Hey guys, just wondering if anyone has any suggestions or potential fixes for the problem.
My buddies 05 sportsman 500 doesn't engage the 4x4 unless you hold the override button. He doesn't have a service manual or I would check there. Just trying to help him get his machine fixed up and save him some money.
Thanks for any and all help you can offer.
The override is designed to override the reverse safety feature. I believe it disables 4wd in reverse also. If his 4wd only engages in high or low while pressing the override then it's possible that the shifter linkage (should be a electrical connector at the trans where the linkage is) isn't telling the override that it's not in reverse.
Yeah, his speedo isnt showing what gear he is in and speedo only seems to work when override is pushed in
You've got it exactly backwards cutout. In reverse, you have full power and AWD works ONLY if you press the button!! Its a safety feature to keep you from killing yourself.
