1 - 11 of 11 Posts
2005 500 efi, piston burned/scored bad. Gouged cylinder bad, deeper than deep. In looking for a piston and cylinder, the efi piston, rings and cylinder are a different part number than carb models supposedly. Lower end parts are the same numbers.
eBay has piston and cylinder kits quite reasonably. They cover many years (1996-2012). Does anybody have any experience in using an ebay piston/cylinder kit on an efi even though efi parts are listed differently?
Has anybody run across this before?
Thanks.
to the forum
Your question has now been logged into the queue and the next available forum member will answer you shortly. You will be given more advice than you could hope for.
The real shortage in this country is common sense.
Thanks.
2005 Sportsman 500 carb model piston part number 3087221
2007 Sportsman 500 EFI model piston part number 3087221
2005 piston was used in the following models:
2003 500 MAGNUM 4X4 HDS (A03CD50FB) - Crankshaft & Piston
2003 SCRAMBLER 500 4X4 (A03BG50AA) - Crankshaft And Piston
2003 SPORTSMAN 500 HO (A03CH50AA/AB/AC/AD/AE/AH/AJ) - Crankshaft And Piston
2003 SPORTSMAN 6X6 (A03CL50AA) - Crankshaft And Piston
2004 A04BG50AA SCRAMBLER 500 4X4 (A04BG50AA/FA) - Crankshaft And Piston
2004 A04CH50AA SPORTSMAN 500 (A04CH50AA/AC/AE/AG) - Crankshaft And Piston
2004 A04CH50AQ SPORTSMAN 500 (A04CH50AO/AQ/AR/AS/AT/AV/AW/AX) - Crankshaft And Piston
2004 A04JD50AA ATP 500 4X4 (A04JD50AA/AB/CA) - Crankshaft And Piston
2004 RANGER 2X4,4X4,6X6 (A04RB42AA) - Crankshaft & Piston /A04rd50aa/Ab/Ac/A04rf50aa
2004 SPORTSMAN 6X6 (A04CL50AA) - Crankshaft And Piston
2005 ATP 500 4X4 (A05JD50AA) - Crankshaft & Piston /Ab/Ac
2005 RANGER 2X4,4X4,6X6 (R05RB50AA/RD50AA/AB/AC/AD/RF50AA/AB) - Crankshaft & Piston
2005 SCRAMBLER 500 4X4 (A05BG50AA) - Crankshaft & Piston /Fa
2005 SPORTSMAN 500 HO/INTL (A05MH50AB) - Crankshaft & Piston /Ac/Ag/Ah/Al/At/Fb
2005 SPORTSMAN 6X6 (A05CL50AA) - Crankshaft & Piston
2006 RANGER 500 2X4/4X4 (R06RB50AA) - Crankshaft & Piston /Rd50aa
2006 RANGER 500 4X4 EFI (R06RD50AC) - Crankshaft & Piston R06rd50ab/Ac
2006 SCRAMBLER 500 4X4 (A06BG50AA) - Crankshaft & Piston /Fa
2006 SPORTSMAN 500 EFI (A06MH50AQ) - Crankshaft & Piston /Ax/Ay/Az/Al/At
2006 SPORTSMAN 500 EFI INTL (A06MH50FC) - Crankshaft & Piston
2006 SPORTSMAN 500 HO (A06MH50AA) - Crankshaft & Piston /Ab/Ad/Af
2006 SPORTSMAN 500 HO INTL (A06MH50FB) - Crankshaft & Piston
2006 SPORTSMAN 6X6 (A06CL50AA) - Crankshaft & Piston
2006 SPORTSMAN X2 (A06MN50AU) - Crankshaft & Piston /Aw
2007 RANGER 500 2X4/4X4 (R07RB50AA/RH50AA) - Engine, Crankshaft & Piston
2007 RANGER 500 EFI 4X4 (R07RH50AF/AR/AT) - Engine, Crankshaft & Piston
2007 SCRAMBLER 500 2X4 INTL (A07BA50FA) - Engine, Crankshaft & Piston
2007 SCRAMBLER 500 4X4 (A07BG50AA/FA) - Engine, Crankshaft & Piston
2007 SPORTSMAN 500 EFI (A07MH50AB/AL/AQ/AX/AY/AZ/MN50AF/AN/AT/AY) - Engine, Crankshaft & Piston
2007 SPORTSMAN 500 EFI INTL (A07MH50FC) - Engine, Crankshaft & Piston
2007 SPORTSMAN 6X6 (A07CL50AA) - Engine, Crankshaft & Piston
2007 SPORTSMAN X2 500 EFI (A07TH50AL/AQ/AU/AZ/TN50AF/AS/AU) - Engine, Crankshaft & Piston
2007 SPORTSMAN X2 500 EFI QUAD (A07TH50EA) - Engine, Crankshaft & Piston
2008 RANGER 4X4 500 EFI (R08RH50AF/AR/AT) - Engine, Crankshaft & Piston
2008 RANGER 500 2X4 (R08RB50AA) - Engine, Crankshaft & Piston
2008 SCRAMBLER 2X4 INTL (A08BA50FA) - Engine, Crankshaft & Piston
2008 SCRAMBLER 500 4X4 (A08BG50AA) - Engine, Crankshaft & Piston
2008 SCRAMBLER 500 4X4 INTL (A08BG50FA) - Engine, Crankshaft & Piston
2008 SPORTSMAN 500 EFI SCANDINAVIAN (A08MH50SS/SQ) - Engine, Crankshaft & Piston
2008 SPORTSMAN 500 HO (A08MH50AX/AZ) - Engine, Crankshaft & Piston
2008 SPORTSMAN 500 HO EFI (A08MN50AF/AN/AQ/AR/AS/AT/AW/AX) - Engine, Crankshaft & Piston
2008 SPORTSMAN 6X6 (A08CL50AA) - Engine, Crankshaft & Piston
2008 SPORTSMAN TOURING 500 EFI (A08DN50AF/AS/AW/AZ) - Engine, Crankshaft & Piston
2008 SPORTSMAN TOURING 500 EFI QUAD (A08DN50EA) - Engine, Crankshaft & Piston
2008 SPORTSMAN X2 500 EFI (A08TN50AT/AX/AZ) - Engine, Crankshaft & Piston
2008 SPORTSMAN X2 500 EFI QUAD (A08TN50EA) - Engine, Crankshaft & Piston
2009 RANGER 2X4 500 CARB (R09RB50AF) - Engine, Crankshaft & Piston
2009 RANGER 4X4 500 EFI (R09HH50AG/AR) - Engine, Crankshaft & Piston
2009 SCRAMBLER 2X4 INTL (A09BA50FA) - Engine, Crankshaft & Piston
2009 SCRAMBLER 500 4X4 (A09BG50AA) - Engine, Crankshaft & Piston
2009 SCRAMBLER 500 4X4 INTL (A09BG50FA) - Engine, Crankshaft & Piston
2009 SPORTSMAN 500 EFI (A09MN50AN/AX) - Engine, Crankshaft & Piston
2009 SPORTSMAN 500 EFI TRACTOR (A09MN50ET) - Engine, Crankshaft & Piston
2009 SPORTSMAN 500 HO (A09MH50AS/AX/AZ) - Engine, Crankshaft & Piston
2009 SPORTSMAN TOURING 500 EFI (A09DN50AB/AZ) - Engine, Crankshaft & Piston
2009 SPORTSMAN TOURING 500 EFI QUAD (A09DN50EA) - Engine, Crankshaft & Piston
2009 SPORTSMAN X2 500 EFI (A09TN50AX/AZ) - Engine, Crankshaft & Piston
2009 SPORTSMAN X2 500 EFI QUAD (A09TN50EA) - Engine, Crankshaft & Piston
2010 RANGER 4X4 500 EFI (R10TH50AG/AR) - Engine, Crankshaft & Piston
2010 SCRAMBLER 500 4X4 (A10NG50AA) - Engine, Crankshaft & Piston
2010 SCRAMBLER 500 4X4 INTL (A10NG50FA) - Engine, Crankshaft & Piston
2010 SPORTSMAN 500 EFI TRACTOR (A10MN50ET) - Engine, Crankshaft & Piston
2010 SPORTSMAN 500 HO (A10MH50AJ/AX/AZ) - Engine, Crankshaft & Piston
2010 SPORTSMAN 500 HO INTL (A10MH50FX/FF) - Engine, Crankshaft & Piston
2010 SPORTSMAN TOURING 500 HO (A10DH50AX/AZ) - Engine, Crankshaft & Piston
2010 SPORTSMAN TOURING 500 HO INTL (A10DH50FX) - Engine, Crankshaft & Piston
2011 RANGER 4X4 500 CREW (R11WH50AG/AH/AR) - Engine, Crankshaft & Piston
2011 RANGER 4X4 500 EFI (R11RH50AG/AH/AR) - Engine, Crankshaft & Piston
2011 SCRAMBLER 500 4X4 (A11NG50AA) - Engine, Crankshaft & Piston
2011 SCRAMBLER 500 4X4 INTL (A11NG50FA) - Engine, Crankshaft & Piston
2011 SPORTSMAN 500 HO (A11MH50AX/AZ) - Engine, Crankshaft & Piston
2011 SPORTSMAN FOREST 500 (A11MH50FF) - Engine, Crankshaft & Piston
2011 SPORTSMAN FOREST TRACTOR 500 EFI (A11MN50ET) - Engine, Crankshaft & Piston
2011 SPORTSMAN TOURING 500 HO (A11DH50AX/AZ) - Engine, Crankshaft & Piston
2011 SPORTSMAN TOURING 500 HO INTL (A11DH50FX) - Engine, Crankshaft & Piston
2012 RANGER 500 4X4 (R12RH50AG/AH/AM/AR/AZ) - Engine, Crankshaft & Piston
2012 RANGER 500 4X4 CREW (R12WH50AG/AH/AK/AR) - Engine, Crankshaft & Piston
2012 SCRAMBLER 500 4X4 (A12NG50AA) - Engine, Crankshaft & Piston
2012 SCRAMBLER 500 4X4 INTL (A12NG50FA) - Engine, Crankshaft & Piston
2012 SPORTSMAN 500 HO (A12MH50AD/AO/AQ/AX/AZ) - Engine, Crankshaft & Piston
2012 SPORTSMAN FOREST 500 (A12MH50FF/FX/FY) - Engine, Crankshaft & Piston
2012 SPORTSMAN FOREST TRACTOR 500 (A12MN50ET/EX) - Engine, Crankshaft & Piston
2012 SPORTSMAN TOURING 500 HO (A12DH50AX/AZ) - Engine, Crankshaft & Piston
2013 RANGER 500 CREW MIDSIZE (R13WH50AG/AH/AR/AX) - Engine, Crankshaft & Piston
2013 RANGER 500 MIDSIZE (R13RH50AG/AH/AM/AR) - Engine, Crankshaft & Piston
2013 SPORTSMAN 500 HD (A13MH50TD) - Engine, Crankshaft & Piston
2013 SPORTSMAN 500 HO (A13MH50AJ/AQ/AX/AZ) - Engine, Crankshaft & Piston
2013 SPORTSMAN FOREST 500 (A13MH50FF/FJ/FU) - Engine, Crankshaft & Piston
2013 SPORTSMAN FOREST TRACTOR 500 (A13MN50ET/EX) - Engine, Crankshaft & Piston
2013 SPORTSMAN TOURING 500 HO (A13DH50AX/AZ) - Engine, Crankshaft & Piston
2014 SPORTSMAN FOREST TRACTOR 500 (A14MN50EM/EA) - Engine, Crankshaft & Piston
SERIES 11 RANGER (A11RB42AA/A11RD50AA/AB/A11RF50AA) - Crankshaft & Piston
SERIES 11 UTV 2X4/4X4/6X6 (C11RB42AA/C11RD50AA/AB/C11RF50AA) - Crankshaft & Piston
The cylinder is another story - the same cylinder was only used on the following models:
2004 A04BG50AA SCRAMBLER 500 4X4 (A04BG50AA/FA) - Cylinder
2004 A04CH50AQ SPORTSMAN 500 (A04CH50AO/AQ/AR/AS/AT/AV/AW/AX) - Cylinder
2004 A04JD50AA ATP 500 4X4 (A04JD50AA/AB/CA) - Cylinder
2004 RANGER 2X4,4X4,6X6 (A04RB42AA) - Cylinder /A04rd50aa/Ab/Ac/A04rf50aa
2004 SPORTSMAN 6X6 (A04CL50AA) - Cylinder
2005 ATP 500 4X4 (A05JD50AA) - Cylinder /Ab/Ac
2005 RANGER 2X4,4X4,6X6 (R05RB50AA/RD50AA/AB/AC/AD/RF50AA/AB) - Cylinder
2005 SCRAMBLER 500 4X4 (A05BG50AA) - Cylinder /Fa
2005 SPORTSMAN 500 HO/INTL (A05MH50AB) - Cylinder /Ac/Ag/Ah/Al/At/Fb
2005 SPORTSMAN 6X6 (A05CL50AA) - Cylinder
2006 RANGER 500 2X4/4X4 (R06RB50AA) - Cylinder /Rd50aa
2006 RANGER 500 4X4 EFI (R06RD50AC) - Cylinder R06rd50ab/Ac
2006 SCRAMBLER 500 4X4 (A06BG50AA) - Cylinder /Fa
2006 SPORTSMAN 500 EFI (A06MH50AQ) - Cylinder /Ax/Ay/Az/Al/At
2006 SPORTSMAN 500 EFI INTL (A06MH50FC) - Cylinder
2006 SPORTSMAN 500 HO (A06MH50AA) - Cylinder /Ab/Ad/Af
2006 SPORTSMAN 500 HO INTL (A06MH50FB) - Cylinder
2006 SPORTSMAN 6X6 (A06CL50AA) - Cylinder
2006 SPORTSMAN X2 (A06MN50AU) - Cylinder /Aw
2007 RANGER 500 2X4/4X4 (R07RB50AA/RH50AA) - Engine, Cylinder
2007 RANGER 500 EFI 4X4 (R07RH50AF/AR/AT) - Engine, Cylinder
2007 SCRAMBLER 500 2X4 INTL (A07BA50FA) - Engine, Cylinder
2007 SCRAMBLER 500 4X4 (A07BG50AA/FA) - Engine, Cylinder
2007 SPORTSMAN 500 EFI (A07MH50AB/AL/AQ/AX/AY/AZ/MN50AF/AN/AT/AY) - Engine, Cylinder
2007 SPORTSMAN 500 EFI INTL (A07MH50FC) - Engine, Cylinder
2007 SPORTSMAN 6X6 (A07CL50AA) - Engine, Cylinder
2007 SPORTSMAN X2 500 EFI (A07TH50AL/AQ/AU/AZ/TN50AF/AS/AU) - Engine, Cylinder
2007 SPORTSMAN X2 500 EFI QUAD (A07TH50EA) - Engine, Cylinder
2008 RANGER 4X4 500 EFI (R08RH50AF/AR/AT) - Engine, Cylinder
2008 RANGER 500 2X4 (R08RB50AA) - Engine, Cylinder
2008 SCRAMBLER 2X4 INTL (A08BA50FA) - Engine, Cylinder & Head
2008 SCRAMBLER 500 4X4 (A08BG50AA) - Engine, Cylinder & Head
2008 SCRAMBLER 500 4X4 INTL (A08BG50FA) - Engine, Cylinder & Head
2008 SPORTSMAN 500 EFI SCANDINAVIAN (A08MH50SS/SQ) - Engine, Cylinder & Head
2008 SPORTSMAN 500 HO (A08MH50AX/AZ) - Engine, Cylinder & Head
2008 SPORTSMAN 500 HO EFI (A08MN50AF/AN/AQ/AR/AS/AT/AW/AX) - Engine, Cylinder & Head
2008 SPORTSMAN 6X6 (A08CL50AA) - Engine, Cylinder & Head
2008 SPORTSMAN TOURING 500 EFI (A08DN50AF/AS/AW/AZ) - Engine, Cylinder & Head
2008 SPORTSMAN TOURING 500 EFI QUAD (A08DN50EA) - Engine, Cylinder & Head
2008 SPORTSMAN X2 500 EFI (A08TN50AT/AX/AZ) - Engine, Cylinder & Head
2008 SPORTSMAN X2 500 EFI QUAD (A08TN50EA) - Engine, Cylinder & Head
2009 RANGER 2X4 500 CARB (R09RB50AF) - Engine, Cylinder
2009 RANGER 4X4 500 EFI (R09HH50AG/AR) - Engine, Cylinder
2009 SCRAMBLER 2X4 INTL (A09BA50FA) - Engine, Cylinder & Head
2009 SCRAMBLER 500 4X4 (A09BG50AA) - Engine, Cylinder & Head
2009 SCRAMBLER 500 4X4 INTL (A09BG50FA) - Engine, Cylinder & Head
2009 SPORTSMAN 500 EFI (A09MN50AN/AX) - Engine, Cylinder & Head
2009 SPORTSMAN 500 EFI TRACTOR (A09MN50ET) - Engine, Cylinder & Head
2009 SPORTSMAN 500 HO (A09MH50AS/AX/AZ) - Engine, Cylinder & Head
2009 SPORTSMAN TOURING 500 EFI (A09DN50AB/AZ) - Engine, Cylinder & Head
2009 SPORTSMAN TOURING 500 EFI QUAD (A09DN50EA) - Engine, Cylinder & Head
2009 SPORTSMAN X2 500 EFI (A09TN50AX/AZ) - Engine, Cylinder & Head
2009 SPORTSMAN X2 500 EFI QUAD (A09TN50EA) - Engine, Cylinder & Head
2010 RANGER 4X4 500 EFI (R10TH50AG/AR) - Engine, Cylinder
2010 SCRAMBLER 500 4X4 (A10NG50AA) - Engine, Cylinder & Head
2010 SCRAMBLER 500 4X4 INTL (A10NG50FA) - Engine, Cylinder & Head
2010 SPORTSMAN 500 EFI TRACTOR (A10MN50ET) - Engine, Cylinder & Head
2010 SPORTSMAN 500 HO (A10MH50AJ/AX/AZ) - Engine, Cylinder & Head
2010 SPORTSMAN 500 HO INTL (A10MH50FX/FF) - Engine, Cylinder & Head
2010 SPORTSMAN TOURING 500 HO (A10DH50AX/AZ) - Engine, Cylinder & Head
2010 SPORTSMAN TOURING 500 HO INTL (A10DH50FX) - Engine, Cylinder & Head
So the same piston was used in more models than the same cylinder was.
Since the cylinder is a steel liner, it's not commonly severely damaged by seizure - I would have the cylinder bored out and fit with a new oversized piston.
OH - BTW, there was no EFI model of the 500 Sportsman offered in 2005 - the only 500 in 05 was model A05MH50AB, but the piston was the same for the 06 Sportsman 500 EFI model A06MH50AQ and A06MH50FC
Discussion Starter · #4 ·
Thank you so much. I will verify if what I was told about the year (2005) is correct. The owner said is was a 2005 and was a dealer demo of some kind - it may have been a sample of what was planned.
Again, thank you so much for the info. I'm assuming the ebay piston/cylinder kits at about $106 US will work.
A cheap QUALITY piston (Namura) is $116 and you can get a piston/cylinder kit for $106? It's your machine and your money, but if you just want it running so you can off it, go for it and get rid of it.
Discussion Starter · #7 ·
It goes without saying the $106 kit (shipped to my door) is probably a Chinese knockoff. That said, the atv doesn't really have a lot of hours on it and the OEM piston/cyl didn't win any honors for longevity.
The kits are on ebay. That's the cheapest I found, there are similar kits with filters, etc for more. I'll agree these are not equal to OEM parts, but then again, fit and finish are expected to be up to normal standards. Hey, I'm no big fan of sending money to China, but when you realize that alot of the OEM parts that come on the atv new are Pacific rim origin already, I'm not sure I'm real scared of cheap clone parts. If the factory puts Chinese, Vietnamese, Indonesian or whatever parts on them at the factory, it won't bother me to put a cheap piston/cylinder on it. Is the steel substandard? Piston cast and machined poorly? Doubtful.
The real problem with this atv is that it is a 2005 and it does have efi, which (by the books) technically doesn't exist. It was a prototype that made it out the doors for dealers to familiarize themselves with and somehow it got sold. Looking at part numbers in books is what got me here in the first place. The gentleman that posted all the piston/cylinder info above was very helpful; now I pretty much know a generic piston will work. The score in the cylinder is deep and after measuring it, I don't think boring the cylinder to max oversize will get rid of it.
I also wanted to know if anybody else had experienced this also and so far, it looks like this is not common.
Thanks for all the replys. Appreciated.
What is it that makes you so certain it's an 05 with EFI? What's the VIN or model number?
I thought 2006 was the first year for EFI?
It was for the 500 - 700 & 800's got EFI in 05 - the OP in under the false impression he's got a prototype probably because it was manufactured sometime after July of 05 or a dealer told him it was a prototype and sold it for $2000 more than the average asking price - the VIN will be the defining factor.
Yep, its hard for some folks to wrap their head around the idea that you can have a 2006 model machine built in 2005. Apparently they think the assembly plant workers change everything over for the next year model's production on New Years Eve lol.
1 - 11 of 11 Posts
