1 - 8 of 8 Posts
Hey guys the female splines on my rear differential are stripped, almost smooth. I am wondering how to go about removing them, hopefully without removing the rear differential from the bike. Any help would be great!
Thanks, Jake
I am afraid the whole gearcase has to come out and apart. From what I can tell, the spline part is just the outside of a gear on the inside. Don't think this is going to be a simple fix
It's not a diff. It's the inside of the output sprocket.
You'll need both sprockets and silent chain.
Go to 3:30 in this video where you can see the sprockets & chain.
This is why you use chaincase oil or Dexron ATF in this box.
https://youtu.be/rQwkmbqSpvc
Sent from my SM-P605V using Tapatalk
At a minimum you'll need number 19.
19 3234421 Subasm., Shaft, 59T, Final Output w/Bearings [Incl. 2 of Ref. 18]
20 is the chain and 29 the other sprocket.
You might just find a good used gearcase for the same money on ebay.
Never replace just one sprocket in a chain & sprocket set. They wear together so a single new sprocket will have accelerated wear vs a new set
You'll need at least 2x #7, 1x #s 19, 20, & 29. 19 comes with both #18 bearings but not the #7 seals.
I'd replace any seals that can be done while it's out.
Check the shift forks and chain tensioner for wear.
You may also find the reverse chain #49 and sprocket set are worn.
In the end an Evilbay gearcase may be much cheaper than repairing your worn chaincase. eBay search Polaris Sportsman Transmission http://r.ebay.com/hqAHGo
I would also replace the rear axles at the same time, as they seem to wear rout together. So in my opinion putting sloppy axles back into new rear end gear will wear out the new gear.
Discussion Starter #8 (Edited)
So after a full tear down of the whole rear end, I have the transmission removed and split. I have checked all bearings all fine, seals are all good (going to replace seals anyway). I am now waiting on the the new sprocket to replace. I rather rebuild myself knowing I have a solid rear end then ordering from eBay used. I am replacing 2 of the rear axels and some bushings virtually giving me a new full rear end (including bearings I done a month ago)
1 - 8 of 8 Posts
