2005 Sportsman 500 Serious power mods
1585 Views 11 Replies 7 Participants Last post by  polman500
Hello everyone, i have a 2005 Polaris Sportsman 500 HO, and finally have the time and money to restore it, and give it some power. I am honestly looking to make as much power as possible, and am fine with the reliability drawbacks, and am going to switch to E85 fuel. I wanted to know what mods are out there, im looking for a good big bore, cam, carb, i have to get a new bottom and top end, so i could get a stroker kit if there is one avialable. I have tried to find these mods with no success, let me know if you guys know of any good mods.
1 - 12 of 12 Posts
Twin Turbo's and afterburner.
Reactions: 1
I was thinking of calling up Elon and getting ahold of one of his rockets and welding that straight to the frame.
E85? Why?
It'll destroy the fuel system components, collect tons of water in an open fuel system like your Sportsman has and I'm not sure how you'd jet the carb to correctly mix a fuel that can vary anywhere from 51% to 85% alcohol depending on geographic location and season.
Keep us posted on how this all works out for you.
If you are looking for more power, E85 or E100 is the wrong way to go - you need a higher BTU/lb fuel not less. Alcohol has about 1/3 less BTU's per pound than gasoline, so fuel economy and power output suffer. Also, you will need a steel fuel tank with about 2/3 more capacity to go the same distance as the OEM tank full of gasoline. You will need steel or copper fuel lines and a carburetor with no rubber parts used in it's construction. You will need to replace the carb holder (rubber) with an aluminum holder. The carb should be a flange mount with a paper gasket and to extract the same amount of HP from the engine using alcohol, it should be super charged or the compression raised to about 250 PSI static (cranking) pressure.
But the project will be fun and you will learn so much about engine building that you will swear off being an an IC engine engineer.
Research the project before starting it to find out exactly what the end result will be.
See less See more
Y'all are crushing his dreams.
The first thing you should tell him is that" Sportsman 500" and "serious power " don't belong in the same sentence
You could increase output by 20% and still be under 40hp.
Sent from my SM-G970U using Tapatalk
I'm more talking about in comparison to stock power, and anyways, there's a guy who makes a stroker kit that someone told me adds 15 or so hp, without any other mods, so considering my budget for this is quite high, I think I've got a good shot at making some power. And worst case, I'll call up Elon and strap a friggin rocket to the back.
maybe do a bit of porting?
The easiest way to get more power out of your 500 is to go buy an 850. ;)
Reactions: 1
This place?
E="Mike_B, post: 1562203, member: 51132"]
This place?
[/QUOTE]
Yep
This place?
Yep
[/QUOTE]
Yep... "They also said artificial sweeteners were safe, WMDs were in Iraq and Anna Nicole married for love..." :unsure:
1 - 12 of 12 Posts
