1 - 20 of 31 Posts
I was want to know if there is a way to test the ecm. I have a 12 volt draw on the battery with the ecm plugged in with the key on the off position if I unplug this the draw goes away. The bike also has no spark. Any help would be appreciated. And thank you in advanced.
I have tested everything that I can. The only thing I can see is there is a 12volt draw with the key off and when I unplug the ecm the draw goes away. So I'm thinking there is a short. What do you guys think.
If you think it is bad, I would pull it and take the cover off. Common cause of them failing is water intrusion. If you see corrosion inside it, you know it will need replacing.
Sean
Discussion Starter · #8 ·
I pulled the cover off there was no water inside of it nor does it look like there ever was some of the MOSFETs look a little discolored but nothing is defantly smoked. With the stator unplugged it still has a draw so I really think its fried.
Without knowing what the normal current draw is, what is the use of knowing what his is?
Sean
Discussion Starter · #16 · (Edited)
I did a amperage test there is a 0.0 draw with the key off and it does not change with the ecm unplugged or plugged in. But there is a 11.75 volt draw with no amps. What the hell is going on here. I have no spark but everything else seems to work as far as I can tell.
Sounds like the ecm is looking for a sensor and can't find it. Maybe you have a bad crank angle sensor, that would keep your spark from working.
12 850EPS Short bus edition
1 - 20 of 31 Posts
