FOR PEOPLE WITH IDLING BUT INSTANT STALL (Can restart immediately)
Have a 05 700 EFI, ran great on a 3 day trip to the lake, brought it home went to go for a ride the next weekend started up and idled. Soon as i touched the throttle it died instantly. First thing I thought of was the ETC, looked like it was working properly. Took a look and measured TPS (all good). As per service manual checked intake and exhaust for blockage, checked fuel pressure (39psi), changed spark plugs, took off-run-off switch apart (Found switch contact plastic melted - new switch required).
With new switch installed, same result, changed throttle assembly (incl ETC).
Runs like new again (ETC afterall! :banghead
Must have been a bad connection in the throttle plugin. I was worried it was the ECU/ECM $$$.
