1 - 15 of 15 Posts
Can some 1 help me?
I have polaris sportsman 700 2005. And it shows check engine icon. I checked and its codes 41 and 46. Can they do some serious damage to my ride? Or how can i fix it? Any suggestions ?
Welcome to the board!:med:
WELCOME!!
That's what I did!
EASY fix good guy on EBay too!
Mine has been fine now for a couple seasons.
Discussion Starter · #7 ·
Ok i found broken wire i fixed it and code 45 disappeared. Now when its working it doesn't show check engine icon but it still shows code 41 and 46 and check engine icon when only display is on. What should I do now ?
SRY FOR BAD ENG !!!
If disconnecting the battery doesn't work you will likely have to replace the entire TBAP connector with the repair kit.
Discussion Starter · #12 ·
Ok i disconnected battery and code's disappeared but it still shows check engine icon does it have to be like that?
So when you run the 3 key on/off diagnostic routine it now goes through to the the WORD "END" with no codes? If so.. never heard of that one... might be bad ECU.
1 - 15 of 15 Posts
