ok my buddy brought his quad over it had no 4x4, we drined the fluid in the front diff, only to get about an once of oil and half a cup of mud,we than ripped the diff out tore it down found the plastic cage was broke into a millon parts, replaced the cage bearings seals, put it back together, before re installing it we plugged it in, now my question is will it engage sitting on the front of the quad or do the rear wheels have to be spinning to engage it, cause right now if you spin the input shaft by hand it does not engage, checked everything all seems to be good 11 volts at the plug,about 23 ohms on the magnet, just wondering were to go next thanks.
