I have a 2006 Polaris Sportsman 450, it has a ticking sound that only occurs in the right rear tire, as well as it only makes that noise when it turns to the right, it sounds ike a bearing to me. Could it be anything else or would you start there?
check the lugnuts. check the axel nut. or jack the rear end up and check for loseness.
Bikerjd
I am having the same problem with my 2003 400 Sportsman. I have checked the wheel side CV joint and it seems to be ok. Let me know what you find out on yours and I will do the same.
Sounds like cv joint. You would have to mic the wear to tell for sure the eye cant see the wear. A ticking is 9 out 10 times the axel.
