My 06 Hawkeye worked fine last week, i took it off the trailer yesterday and when i put it in forward it moved under idle power but when i gave it throttle, it just revved up and didn't respond, the same for reverse. the motor is running fine, just no GO. Can anyone point me in the right direction? Thanks
check your belt
thanks
the belt inside the transmission housing? is there any way to check it without draining the fluid and replacing the gasket.
the drive belt on your clutch drive, check your manual.
