If anyone one could would be awesome. I have a 2006 outlaw 500 irs, it wont start up. Only if is I pulled with my other atv. I thought I had bad rings. I rebuilt the top end. new piston, rings, and new gaskets. I go to start and it sounds like it wants to start but nothing happens. I stick my hand over the exhaust, it back fires on me, and its pushing air out, but its also sucking air in is that normal?
If it doesn't start, then begin at the beginning. Does it have spark? Does it have fuel?
Discussion Starter · #4 · (Edited)
the other thing I don't under stand is how the service manual says that. If u rotate the engine to check timing the position of timing will be different. and then rotate it back to see if it is still timed. and on the forums it shows to look for the T for top dead center but in my book it says to look for the 3 lines the one in the middle?
