When i hit the starter button,Nothing,battery is full charge and i tested starter button and it "closes: when you push it and i have 12 volts to it. I did a starter sylnoid<sp> and still nothing. Need next step please.
Toby
Have you checked the fuses in the fuse panel?? Or have you checked the kill switch is in "On" position?? If those are all good.... Have you tried jumping the solenoid to see if it's the starter itself?? :dunno:
What have you done since the last you started it?
Loan it to a friend? Changed the battery? Had it in storage? Installed a new accessory?
Just trying to find out what happened between the last time you started it and now.
