1 - 2 of 2 Posts
My X2 has no power or lights, but the battery is ok. I found what they call a fusable link which is a terminal connection with what looks like black shrink wrap connected to a red wire. I can't find the other end of the red wire to do a ohm meter check, so what is the easy way to check this fusable link. Or is there another solution to this problem.
did you ever find out what was wrong. I have a very simalar problem on the same x2 wheeler. let me know if you found something out.
thanks
1 - 2 of 2 Posts
