I have had to replace the rubber drive belt now three times. Seems excessive to me. Anyone else have this problem or a suggestion. Thanks.
The late 06 early 07 built rangers did have a bad front motor mount. It is located right by the oil filter. You can pry up on the motor to see if the mount is broken. The drive belt is a replacement part and if you get a 100 plus hours on one that is not to bad. Yes this can be made better we have a clutch kit that consists of a roller secondary clutch that will grip the belt better and run cooler then the stock one. With this kit you will be able to drive your machine in high 99% of the time. If you have any questions you can email me at [email protected] or call 651-340-1129.
And welcome to the board!
do you use high goin up hills real slow if so that would cause one to go bad often and yeah dd dale is right about the motor mount i actually replaced one about 3 weeks ago not to bad to replace.
