1 - 1 of 1 Posts
On my sportsman Ijust picked up the speedo isn't working. Its all wire no cable but is dial type speed display. That isn't working but all other display stuff does. Inside the dash the big plug that goes into the back of speedo there is a blue wire with white stripe that is pulled out of the plug harness. Cld this be the problem? Also if so there are 4 empty slots it could have went into. Does anyone knw what number slot it goes in? Also Inoticed the fan isn't turning on. If Ihook direct power it will work but no power coming through the actual plug for it. I was told there is a heat sensor somewhere on radiator but Icnnt locate any wires going there. I don't really want to direct wire it and have to rely on remembering to turn it on and off every ride.
1 - 1 of 1 Posts
