Im working on a 2006 500,that will start when you turn the key and die within a coupe seconds. This will continue until the machine is warm and then it will run. If you stop and get off and let it cool down the problem starts back up. I've been thru all electical connectors, has no codes, tested stator, coil, fuel pressure, fuel is fresh, spark plug is new, compression and leak down check out. What have i missed? this is one of many that are causing this problem. Thanks for the help.
Welcome.Are you a Polaris mechanic(technician)?
