My sportsman will not disengage from 4x4 no matter how many times I hit the switch what do I need to do to have 2wd
change the diff fluid a few times. change it put some hours on it, repeat 2-3 times.
Is this a common thing with these and are the electrical parts bad about messing up
If you want you can pull the connector apart at the diff. That'll eliminate the electrical end. My thoughts are it's mechanical and the cage is sticking and changing the oil a few times will free it up.
No prob bud. Keep us posted on the progress!!
