My 2006 Sportsman 800 is overheating bad... The first time it happened we parked it after noticing oil in the air filter box. Any ideas about that???
It has continued to overheat and hasnt seen much action lately as I also have 2 2007 Sportsman 800's... I recently cleaned it all up, but while refilling coolant in the radiator I noticed what appeared to be oil floating around in the coolant. ????
After removing circuit breaker & during the test ride, the bike overheated again and blew out coolant everywhere. I found coolant in the air box this time...???
If anyone can provide me with guidance on this matter, I would greatly appreciate it...
seems like a blow head gasket as the others said... SOME oil is normal in the airbox... not much but some...
as for oil in coolant and coolant in airbox/oil then the only 2 possible reasons for it are:
-some friend is pranking you... by doing this at night while you're asleep...
OR
-blown head gasket.....
but im sure its the boogeyman who is scaring you with his pranks......
