Curious if there is some kind of after market kit that would fix this? Currently thinking to weld a plate on it. Other side has a crack as well.
You gotta read this thread! It will at least give you hope and motivation.
Maybe contact Old509cc and see if he could make you the parts.
Mine broke we'll split in the same spot as yours. But I had other frame damage so I just did a while new frame. Old509cc may be able to fab up some new mounts for you 🤞.
Reactions: Tim-ANC
Local non-dealer ATV shop owner said he could weld the cracks and pieces back together and plate it. He won't be able to get to it for a couple days. Super busy time of year for him. My son and I need to tear it down some more to prep for that. Only issue I'm seeing is not having enough thread left over for the top to secure the mount nut to the struts.
The top nut is rather large, for a reason. So I'm sure you could swap that out for a regular nut and lock washer.
Reactions: Tim-ANC
