Anyone have a slick way to remove these ball joints without using the special tool?
153209
You can buy aftermarket for $40 or less.
You can make your own.
Either way, heat is your friend. Nothing too crazy. A basic propane torch for a couple minutes will do the trick.
Good stuff Mike, Thanks. I like the tool you built and the tool you found on Amazon is a lot cheaper than the $89 one I saw on Ebay.
