1 - 2 of 2 Posts
Outlaw 525 SPECIFICATIONS
Engine
Engine Type 4-Stroke SOHC
Displacement 510 cc
Carburetion Keihin
Cooling Liquid
Starting Electric
Drivetrain
Final Drive 520 O-Ring chain
Transmission 5 speed w/reverse
Drive System Hydraulic manual clutch/manual shift
Suspension
Front Suspension Dual A-arm with 10 in. travel
Rear Suspension PRO-IRS with 10 in. travel
Brakes
Front Brakes Dual Hydraulic Disc with dual bore calipers
Rear Brakes Hydraulic Disc with single bore caliper
Tires
Front Tires Maxxis RAZR-R Radial; 21 x 7-10
Rear Tires Maxxis RAZR-R Radial; 20 x 10-9
Dimensions/Capacities
Wheelbase 50.5/128.3 in/cm
Turning Radius (inside tire) 65/165.1 in/cm
Dry Weight 395/179.2 lbs/kg
Length/Width/Height 71.5/47.5/45 / 181.6x120.7x114.3 in/cm
Seat Height 32/81.3 in/cm
Fuel Capacity 3.9/14.8 U.S. gallons/liters
Ground Clearance 11/27.9 in/cm
Instrumentation/Features
Gear Indicator Neutral/Reverse
Warning Lights Hi Temp
Colors
Colors Black
MSRP
MSRP (US$) $7,299
1 - 2 of 2 Posts
