1 - 1 of 1 Posts
Predator 500 SPECIFICATIONS
Engine
Engine Type 4-stroke DOHC
Displacement 499 cc
Carburetion Mikuni 42mm BSR
Cooling Liquid
Starting Electric
Drivetrain
Final Drive 520 O-ring chain
Transmission 5-speed w/reverse
Drive System Manual clutch / Manual shift
Suspension
Front Suspension Dual A-arm with 10in / 25.4cm travel
Rear Suspension Non-link Swing-arm with 11in / 27.9cm travel
Brakes
Front Brakes Dual Hydraulic Disc with single bore calipers
Rear Brakes Hydraulic Disc with single bore caliper
Tires
Front Tires Maxxis RAZR; 21x7-10 in
Rear Tires Maxxis RAZR; 20x11-9 in
Dimensions/Capacities
Wheelbase 50.5/128.3 in/cm
Turning Radius 67/170.2 in/cm
Dry Weight 405/183.7 lbs/kg
Length/Width/Height 71.5/47.5/45, 181.6/120.6/114.3 in/cm
Seat Height 32/81.3 in/cm
Fuel Capacity 3.25/12.3 U.S. gallons/L
Ground Clearance 4.5/11.4 in/cm
Instrumentation/Features
Gear Indicator Neutral / Reverse
Warning Lights High Temp
Colors
Colors White/Black; Black/Silver
MSRP
MSRP (US$) $5,999
1 - 1 of 1 Posts
