I have a 2007 Polaris scrambler 500, started making a clunking or clicking noise when going forward and only under load, I don't hear it in reverse. What I mean by only under load is, if I jack up the rear end tires off the ground, put it in gear and throttle it up it sounds normal, it only makes the noise driving it. You can kind of feel it in the foot rest on the right side mostly also. Looked around and nothing appears out of the ordinary. Any ideas?
Check the ujoints in the front driveline. There is also a slip joint in the driveline that could be dry/worn causing the clunk.
Sounds like a bad axle.
