2007 Ranger 700 won't send power to fuel pump
2324 Views 6 Replies 3 Participants Last post by  latebird
Hi guys,
The voltage regulator and the battery melted while driving. I replaced those but I'm still not getting power to the fuel pump. Any suggestions?
Thanks in advance for any help!
Check the fuse/circuit breakers. Jump 12vdc directly to the fuel pump harness to make sure the pump will actually run.
Hello,
I checked fuse and the fuel pump works with power directly to it.
Check to see if getting power to the pump harness. If not, you probably either have a wire broken/burned into or an ECU problem.
Latebird might be able to shed some light on the matter. He's the resident electrical guru on here.
Reactions: 1
I'll check. Thx for the help!
Update: I don't have spark either.
Sorry - I don't have any info on that unit
Reactions: 1
