1 - 13 of 13 Posts
500 EFI SPECIFICATIONS
Engine
Engine Type 4-stroke
Displacement 499 cc
Carburetion 39mm Throttle Body
Cooling Liquid
Starting Electric with recoil backup
Drivetrain
Final Drive Shaft
Transmission P/R/N/L/H
Drive System Automatic PVT
EBS (Engine Braking System) Standard- Accessory, Deluxe- Standard
ADC (Active Decent Control) Standard- N/A, Deluxe- Standard
Suspension
Front Suspension MacPherson strut with 8.2"/20.8cm travel in/cm
Rear Suspension Fully independent, progressive rate with anti-roll bar; 9.5"/24.1cm travel in/cm
Brakes
Front/Rear Brakes Single-lever hydraulic disc w/ hydraulic rear foot brake
Tires/Wheels
Front Tires 26x8R12; PXT
Rear Tires 26x11R12; PXT
Wheels Standard- Steel, Deluxe- Cast Aluminum
Dimensions/Capacities
Wheelbase 50.5/128.3 in/cm
Turning Radius (inside tire) 65/165.1 in/cm
Dry Weight Standard- 728, Deluxe- 773 lbs/kg
Length/Width/Height 83x48x48 / 210.8x121.9x121.9 in/cm
Seat Height 33.8/85.7 in/cm
Fuel Capacity 4.13 / 15.6 U.S. gallons/L
Front-Rack Capacity* 90/40.8 lbs/kg
Rear-Rack Capacity* 180/81.6 lbs/kg
Hitch Std / Receiver
Hitch Towing Capacity* 1225/555.7 lbs/kg
Braked Trailer Towing Capacity 1,786/810 lbs/kg
Hitch Tongue Weight* 120/54.4 lbs/kg
Ground Clearance 11.3/28.6 in/cm
Instrumentation/Features
Gauge Type Digital
Speedometer/Odometer Standard
Tachometer Standard
Tripmeter Standard
Hourmeter Standard
High Beam Indicator Standard
Gear Indicator Standard
Fuel Gauge Electric
Warning Lights Hi Temp / Low Battery
Rear Work Lights Standard- Accessory, Deluxe- Standard
DC Outlet Standard
Winch Pre-Wire Standard
Colors
Standard Green/Black; Black/Silver; Red/Black; New Break-up Camo ($400 upgrade)
Deluxe Blue/Black; Black/Silver
MSRP (US$) Standard: $6,999 / Deluxe: $7,699
Discussion Starter #2
Engine
Displacement 499 cc
Cooling Liquid
Starting Electric
Drivetrain
Final Drive Shaft
Suspension
Rear Suspension Fully independent, progressive rate with anti-roll bar; 8.5"/22.2cm travel in/cm
Brakes
Tires/Wheels
Front Tires 25x8-12
Rear Tires 25x11-10
Wheelbase 57/144.8 in/cm
Turning Radius (inside tire) 82/208.3 in/cm
Dry Weight Standard- 798; Deluxe- 833 lbs
Length/Width/Height 93x48x48 / 236.2x121.9x121.9 in/cm
Seat Height 34/86.4 in/cm
Fuel Capacity 6 / 22.7 U.S. gallons/L
Rear-Rack Capacity* 400/181.4 lbs/kg
Hitch Towing Capacity* 1225/555.6 lbs/kg
Braked Trailer Towing Capacity 1,995/905 lbs/kg
Ground Clearance 11/27.9 in/cM
Gauge Type Digital
Tachometer Standard
Tripmeter Standard
Hourmeter Standard
Fuel Gauge Electric
DC Outlet Standard
Colors
Standard Black/Silver, Red/Black; New Break-up Camo ($400 upgrade)
MSRP (US$) Standard: $7,899 / Deluxe: $8,599
1 - 13 of 13 Posts
