First timer here Thank you for having me.
I have what seems to be a common issue with these and before I spend the $$ to buy a new control module I have to ask the Experts. I have traced power
all over and this is a couple questions I have,
1st) I have not power to anything now, but at first if I left the key in the ON position it would click on the dash but then off again.
as if it was trying to power on then minutes later same thing.
2nd) I replaced the easy things like the starter solenoid and ignition switch at least they are new now Lol.
3rd) I have power (12v) to Control Module BUT I removed the outlet plug and tested on that side All but 1 plug on that side have odd voltages, the 12.19 is close to battery voltage at the battery I had 12.77v.but as you see I'm getting anything from 4v,5v,9v on everything else I'm at a loss is the control module bad or am I doing something wrong????
