No spark on my Sportsman, I replaced the Stator and Crank Position Sensor not too long ago and it ran great for a while.
I checked the stator and CPS and they are still in spec, I checked the CPS gap and that is OK. Tried to disconnect the black wire from the key and still no spark.
Tested the ignition coil and it measures to spec.
I see the ignition coil is connected between the ECU and the PDM. How do I determine which is causing the issue?
Is there something else I should be looking at? The speedometer comes on and indicates OK and the starter turns, but no spark. I thought I remembered I could hear the fuel pump click on when I turned the key, but I don't hear that now. (I may be mistaken on this one.)
I see ModuleMasters rebuilds the PDM, I would like to somehow determine if that is the problem somehow before pulling it and sending it off.
Thanks for any ideas in advance,
