I have a 2007 Sportsman 500 HO EFI, and I need to test the fuel pressure. Problem is, there's not a schrader valve on the fuel rail.
How do you test fuel pressure on these machines?
Welcome to the forum
Take the quick connect fitting loose at the tank and clamp a hose for your gauge on the pump outlet. Then turn on the key.
If you want to check while running you'll need to fashion a T fitting to add the gauge on.
Should have 38-42 psi IIRC.
Organism Font Slope Auto part Parallel
Yep. That would work even better OP ^^
I forgot to mention that with my shade tree method you'll need to bleed the air off the line to get an accurate reading and cycle the key 3 or 4 times. If the pump is bad it's usually pretty obvious.
